Shows Fabric Attach authentication information.
| ports | Specifes ports to show. |
| port_list | Specifies the list of ports to show. |
| all | Shows information for all ports in the system. |
| authentication | Specifies showing Fabric Attach authentication information. |
| detail | Specifies showing detailed Fabric Attach authentication information. |
N/A.
This command shows the configuration settings from the configure fabric attach ports [port_list | all] authentication [ disable | enable | key {key | default | encrypted encrypted_key}] command.
# show fabric attach ports 1 authentication Port Authentication --------- -------------- 1 Enabled
show fabric attach ports all authentication detail Port Authentication Encrypted Key --------- -------------- ----------------------------------------------------------- 1 Enabled "#$GuZJvU40xnRwKd+PUlsBxSwfpQYr5w==" 2 Disabled "#$4MoonVveq8vrk9BrKO9I673CCDfnWUEcAcKeTZcvQup3XFApn36GWvMGXAl3TpufrUXPZPV2geztybwV/0xfLoFt+zg/4g=="
This command was first available in ExtremeXOS 30.2.
